Help Speccing a Machine
15 Jun 2006
Hi everyone,
this is a standard thread asking for help from someone who's been out of touch for a while! :) So, thanks to all for your advice.
I'm building a new machine that I will use specifically for software development. I do a lot of virtualisation, so need 8 to 16gb of memory, and plenty of cores if possible. Gaming is also on the agenda, but I do not need the best gfx card in the world - DX11 is important though.
I'm looking to get one of the Lian Li PC-V351 cases, so need everything to fit in there.
I don't need a monitor (but recommendations for a 24" would be nice), keyboard, mouse or speakers.
To spend, lets say 500-1000 quid. I'm more interested in a decent spec and recommendations for what I should get, budget could change.
I need to buy something in the next 2 to 3 weeks.
Thanks for all your help,
TM
Guys,
thanks so much for the replies.
Are AMD back in the game (performance/reliability)? The last time I bought a machine, Core 2 Duo was the king, and AMD were no where to be seen. Is this still the case?
Cheers
TM
thanks Freddie, appreciate your help.
I'm not too worried about the fastest ram, so long as it's reliable - as i don't think the expense would be something I would notice from a performance perspective, and I won't be overclocking.
Cheers
TM
