Hey guys,
At the moment I’m looking to replace my now 3 year old PC, which has a propensity to break down and is no longer under warranty, and was looking for some advice, though you’ll have to excuse me if I sound a bit dim as I’m new to speccing PCs. I’m looking to hopefully get something that should last at least 3 years, hopefully longer if I start tweaking things further down the line. Because of my inexperience, I've tried to find some sort of target to try and aim for, so I’ve been looking at the Mafia 2 PhysX/APEX requirements, which are as follows:
I don't need a sound system, keyboard/mouse, monitor or OS, and at the moment I have a tentative budget of around £1500, though I may go a bit higher depending on what comes up, so I guess my first question would have to be: Is it possible to get a PC along those sorts of specs under my kind of budget, or am I aiming far too high?
I do have more questions, but I guess I should probably see what the answer is to that first question so I don’t get ahead of myself.
I’d really appreciate any help you can give (I must admit, I feel rather guilty asking so soon after joining the forums).
Thanks in advance,
Cam
PHYSX/APEX ENHANCEMENTS SYSTEM REQUIREMENTS
Operating System: Microsoft Windows XP (SP2 or later) / Windows Vista / Windows 7 Minimum Processor: 2.4 GHz Quad Core processor
Recommended Processor: 2.66 GHz Core i7-920 RAM: 2 GB
Video Cards and resolution: APEX High settings
Minimum: NVIDIA GeForce GTX 470 (or better) and a dedicated NVIDIA 9800GTX (or better) for PhysX
Recommended: NVIDIA GeForce GTX 480 for Graphics and a dedicated NVIDIA GTX 285 (or better) for PhysX NVIDIA GPU driver: 197.13 or later.
NVIDIA PhysX driver: 10.04.02_9.10.0522. Included and automatically installed with the game.
Thanks in advance,
Cam
