- 26 Feb 2009
Hi,
I need to build a new PC. I will be using it primarily for trading from home. I have a budget of about £1000, my main requirements are as follows...
The main aspect of the build I'm concerned about is the graphics card and the triple monitor setup. I've never hooked up more than two monitors to a system before so I'm a total newbie.
Any spec recommendations would be greatly appreciated!
- I need to be able to hook up three 24 inch monitors initially, however it would be nice to have the flexibility to add a fourth monitor in the future.
- It needs to be fairly quick and have quite a bit of RAM as the trading applications I use are quite resource intensive.
- It needs to have a fairly large hard drive but nothing mega, probably about 500GB.
- I might play some games on it but probably not very often, I'm not too worried about it being a 'Gamer PC' but it would be nice to use it to play games on every now and then.
- It needs to be fairly quiet as I will be using it for 8 hours a day whilst working.
