- 15 Nov 2008
- In the ether
Hi All,
Well I think it's finally time to properly sort out my home network and replace / upgrade it all.
I was hoping you guys could walk me through what I need and how to achieve it.
Basically I have to two systems which I access via ssh or VNC to do development on, but I don't want them to be on all the time (just when I want to use them). One is a Intel Mac and the other a multicore standard desktop with a decent GPU (for CUDA work).
Now at the moment I use a relatively high performance PC to do the remote dev work which seems pointless? I was thinking of replacing it with a low power Atom based machine whose sole duty is to access the other machines - and perhaps play a video or two. How easy is it to WoL so that if I'm on the atom machine and need some extra "grunt" it'll startup the other machines so I can ssh into them?
Also at the moment I have a USB attached Laser printer which I want to be able to access from any machine on the network - is there such a thing as a USB - Network print server?
With repsect to the network itself, I'm just using one 8 port swtich to connect all the machines, but I want to move to a situation where I have all the local machines connected in a trusted way (is that a DMZ?) and a seperate area for things that are connected to the web with little filtering. How do I achieve this?
I'd appreciate any help and advice as I'm really a n00b with respect to setting up a "proper" network.
