Basically got £1,000 to spend on some new PC components, I have a case, HDD and PSU. So what I need is Graphics Card, CPU, Heatsink, RAM, Soundcard and Mobo. Going to be used for Multimedia and Heavy Gaming. Cheers guys!
Case is Thermaltake VA9003SWA Kandalf Aluminium Full Tower - Silver
I have IDE and Sata HDD.
I plan to do some mild overclocking.
Gaming at 1920 x 1200 resolution.
PSU is Cooler Master 550W "Real Power" Power Supply
Hi all, thanks for the replies. my friend msm722 made the thread on my request.
A few points though;
Gigabyte GA_P35_DS4 (Socket 775) PCI-Express DDR2 Motherboard - doesn't have a firewire port will that be a problem? Also it is good for everclocking?
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz (1333FSB) - that is better then Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB)? From the reviews I have read you can really overclock this up to 3.4ghz.
Going from Alex U
k's post i suspect the psu might not be powerful enough to handle the rig, any suggestions?
And finally, the price cuts are only on the cpus or on all the products?
