First time builder
mobo asus p7p55d-e
case is storm scout
psu- antec tru power 550w modular
1)are my cha_fan1 and cha_fan2 4 pin connectors meant to be empty? I
2) i am confused about the molex connections that come with the case. There is one molex behind the motherboardin in a zip tie (should i use it) connecting it lights hdd up + spins.
there are then 3 molex conections from the case should i connect these to my psu. my psu has a molex cable but on the same cable it has a 4 pin connector which seems should go in on of the cha_fan slots?
3)on powering up my cha_fan2 light is red. also initail start up fails i have to presspower button again to start it.
i know its a mouthful but any help is appreciated
thanks
mobo asus p7p55d-e
case is storm scout
thanks
