HELP!! strange monitor problem
4 Aug 2006
Stevenage , Wisbech
Think my monitor has gone strange!! I thought i had a GFX card fault the other day as i switched on the pc and the screen was all distorted, checked out the card cpu mem etc all ok. Then decided to use an old crt monitor and and its fine. Went back to the TFT and the screen is fine while its posting and in bios but as soon as it gets past posting and starting to load windows the screen goes all white with strange patterns moving across it! And keeps like that. Tried to reset the display and still does the same cant think what else to try any ideas???
OK check refresh on my crt it starts at 70hz then switches back to 60. If I boot with CRT then plug in my TFT its ok when windows is loaded :confused: . It maybe a bios type thing somewhere not sure where though. Its ok if i leave it on ha ha and get my nice shiny asus p5w on tues so ill see what will happen then
