for the last few weeks I have been researching day in and day out to try and find out what I should buy.
In october, I will be building a new system, however I cannot decide at all on the sort of set up to go for (amd/ati, intel/nvidia)
I have been swaying towards an intel nvidia set up, and these are the advantages/disadvantages I have identified.
Intel / nvidia set up
Advantages
Disadvantages
Premium pricing, the cost of an intel set up is much more expensive which means the products I get will not be as high quality as the products I could afford If i went for a AMD set up.
I could afford a 5970 if I went for an AMD set up, instead with this set up I can only afford a 470, which if I understand may struggle to run 3D vision or games such as crysis on high resolution / max settings on a 23.6 acer monitor.
ATI set up
Advantages
so please, someone give me some advice on what one to go for! obviously I wont be buying my kit until the begining of october (by which time ati should be releasing the new 6000 series which means the 5970 price may be slashed!
Advantages
- 3DVision, ability to play games/films in 3D (this is the main reason I want to get an Intel/nvidia set up.
- Intel i7 is better for gaming and is overall a much better CPU
- 6gb of DDR3 RAM, (I have read that while the performance boost is minimal, it is still there over a DDR3 dual channel set up
- X58 and its components are generally better than that of the AMD FX set up
120HZ Monitor, another important reason why I want to get an intel set up, 120hz will be great, the thing is if it supports 3d I would really wanna get it, and by getting an ATI set up I wouldnt be able to use it.
I could go SLI obviously if the 470 was not enough.
Disadvantages
ATI set up
Advantages
- Able to pound any game with a 5970, would not bother with a 5870 as I might aswell get a intel set up if i chose to get a 5870
- Much cheaper, meaning able to afford other products, higher quality psu's, more expensive ram etc
ATI bringing out new range in november/october meaning the 5970 price should be slashed!
- AMD is known for the budget market, and having read benchmarks all of the i7's beat it hands down, you get what you pay for.
- No 3d Vision
- Is it worth spending 270 on a 120hz 3d monitor if I cant even use the 3D feature? Might aswell spend 150/200 on a nice normal tn panel, but I would really love to have the new technology
