HELP TEAMFORTRESS 2 :@
11 Mar 2009
so basically i click the TF2 icon and it opens in a window, loads the intro then the window closes. ive tried reinstalling but no luck. please can you guys help me. thanks
First can you give us a rundown of your hardware and any overclocking you may have applied.
Secondly, you tried re-installing, was that by deleting the local content and re-downloading from steam? If not then perhaps you can verify the integrity of the local game cache by right clicking the icon->properties->local files->verifiy integrity of local games cache.
You could also try defragging the games cache. I find a mixture of these normally solve my Steam games problems.
sounds like youve changed your resolution that your monitor doesnt support and reloaded the game.
Go to Steam
Select Games Tab
Right click TF2 > properties
Set launch options
Type in "-height #### -width ####"
Without the quotes and with your monitors screen resolution.
its ok now guys i typed in -dxlevel90 nad its sorted
Go to Steam
Select Games Tab
Set launch options
ive sorted that one out but when i try to change the aspect ratio to 16:10 it wont let me, my monitor is 19 inch wide screen so it shud work ive don it on other games and changed the resolution to 1440 x 900 which a 19 inch wide should be. any ideas?
