Help Think Have bent mobo socket pin
4 Mar 2008
Wandsworth
Help I am not sure if i have bent a socket pin
When I removed th cover it jerked downwards and it may bent a pin what can i do
Please Help
You're not sure?
It's either bent or it isn't?!
If you just brushed the pins, they won't necessarily be broken or bent.
Use your eyes, or a magnifying glass if you have one, and see if you can see any bent pins....
I wouldn't worry about it.
I'd certainly atleast try out the board before panicing.
