Help - Thunderbird won't get my emails!!
17 Dec 2004
Crawley, WEST SUSSEX
I had to do a complete reinstall of XP and I am now putting all the programs back on. I installed Thunderbird and setup my Yahoo and Mac accounts no problem. And on the Yahoo Account it got most of the emails from the server apart from 25 or so and now its showing this message:
The RETR command did not succeed. Error retriving a message. Mail server pop.mail.yahoo.com responded: problem retriving message.
Now before it worked fine and I am not sure what to do, I even reinstalled Thunderbird with no luck. I am just using a standard Yahoo account if that makes a difference.
Weird. So it got some of the emails but not all? That implies the settings are correct. Are you sure you have the right ports or SSL enabled if needed?
Yeah there were around 150 email for it to get and it popped up that message when there were around 25 to go, which is just plain weird never had this problem before. Apparently SSL isn't supported so thats not it and I assume the port is right as it got some of the emails :confused:
I will check on my Tiger install where I also have Thunderbird to see if thats doing it. Do I have to have a special account for Yahoo now to download the emails or something?
Well that sucks. That must have been a change recently as it was working fine before I reinstalled. Gonna check my Mac Tiger install but I am hoping that will still work.
Thanks for all the advice. My mac settings are the same as my windows settings and emails work fine on the mac. Its not a problem anymore as the message isn't coming up on windows thunderbird anymore so I am thinking it must have been a problem on the server. Thanks again though for your help.
Edit: And by the way you so not need yahoo plus to use 3rd party email software.
