- 7 Aug 2009
Hi guys,
I'm looking at composite doors and I had in mind £500 would do the job, but it seems there are tons of brands which have no proven reputation and lots of horror histories after a couple of weeks researching on google. I'm looking for a long term quality door, but I was hoping to not spend much, but perhaps what I want is not possible. The 2 brands that come up a lot is Solidor and Rockdoor, but comes with a higher price tag. if I can't find any alternative to them that can offer quality and peace of mind, so be it, I'll have to spend more. If there are well know manufactures/installer that you guys could recommend, then I would be very happy
I've gathered some information and it seems there are a few things to take into equation:
I've found http://www.rightdoor.co.uk/ to sell Rockdoor installed in London for £1117 VAT inc http://www.rightdoor.co.uk/rock-door-ultimate/vermont/plain-glazed which so far is the cheapest I've come across online and I've seems a few success histories with them on the forums. http://www.phglazingsolutions.co.uk/ doesn't give prices but seem to have good reputation on checkatrade.com which I like, this shows transparency of the business.
I could not get quotes yet from Solidor as their installer finder system is not working on their website. What prices should I expect from a basic door like the Vermont on the link above?
There are a few other brands/shops that I've come across but I'm not sure what to say, these are my findings:
Apologies for the long post, perhaps I'm thinking too much about what would work for me, but considering the costs I think it is worth one I decide to go ahead to get the best I can for my hard earned money.
Could you guys please share your thoughts? I would really appreciated it!
- South facing door, sunlight and door/frame expanding
- Darker colours tend to fade after a while, especially red
- Solidor has timber core, while Rockdoor has foam core. I don;t expect someone to come and pierce my door, but Solidor would have an upper hand in my opinion. Rockdoor carbon fibre seems to only add rigidity to the frame
- Low profile aluminium thresholds are prone to draught and water leak in some situations, perhaps use a regular door frame all around
- Does the letterbox affect much the insulation?
- I would like to have a Yale Conexis L1 smart lock in place. It seems any regular multilock system can do it as long the middle of door handle and the cylinder are 92mm apart
- http://www.hormann.co.uk/ high quality, perhaps better than Rockdoor and Solidor but very expensive
- https://www.compositedoorshop.co.uk/ saw some people recommending them, but I've no idea what door brand they use, I'm afraid of low quality chinese imports
- https://www.valuedoors.co.uk/composite-doors Rockdoors are about £1350+ and some reports that they are not good, they seems to be just a broker in the end
- https://www.abbeywindows.co.uk/upvc-doors/ultimate-composite-doors/ not sure if the ultimate door they sell is actually Rockdoor
- http://www.heritagetradeframes.co.uk/ just another composite seller or manufacturer, not sure if they are any good
- https://www.trade-upvc.co.uk are based in South London, that is the only reason I mentioned as I'm planning to visit their shop
- http://endurancedoors.co.uk/ have very good website and marketing material, no idea if the doors are also any good? The brochure has a lot of information http://endurancedoors.co.uk/resourc...a89d998c/endurance_doors_brochure_low_res.pdf
- http://www.compositedoorprices.co.uk/solidor-composite-doors/ seems to use other websites to give prices, not sure if they are just another broker?
- http://www.rocksolidoors.co.uk/component/virtuemart/solidor.html the only website so far with Solidor prices
at the RRP of the top-end composite doors they offer.
