Help to OC 5870XF MSI Afterburner
21 Aug 2006
Hi
I have a sapphire and an asus 5870 (both v1) cards. Is it possible to link the overclocks and voltages so i dont have to switch between cards?
Also, I followed the instructions in here ATI 5870 flash to bypass 900/1300 limit to flash the sapphire card but i dont think it worked as i still seemed to be limited to 900 core in MSI Afterburner :confused:
Also, is it right that CCC no longer shows the Overdrive section with xfire enabled?
Finally what is the recommended safe voltage for these cards? It has defaulted to 1.162v. Anyone got the correct Asus 5870 BIOS as GPUz wont let me save the BIOS currently on the Asus card :confused:
TIA
