hi guys, brand new to overclocking, so be gentle with me
i got the asus p5n-d mobo i heard its not the ideal OC'n mobo but all help is needed
also got a standard 550W psu its HEC or something it came with the pc from mesh.
i got the artic 7 freezer pro on my cpu the 8800gts (512) gpu and 4gb crucial ballistix pc 8500. and on vista 32bit.
i got a 80mm fan in the front of my case blowing air in andother 80mm fan blowing air onto the mobo from side and obviously the 120mm on the back.
also got the NB fan on supplied with the mobo.
i had my cpu at 3gig for a bit but kept on BSOD every so many hours of gaming, i ran prime95 and it would run for like 10 - 20 secs b4 BSOD.
so i just dont know what to do when it BSOD if i need to lower something or raise something or what. how do you find out?. i obviously know there are no set voltages to get you to 3 gig but i read differentt hing that people tried and started from there. but i think the setting i had was vcore at 1.4V dram on 2V ht 1.38V NB 1.4 and the sb auto fsb was 1335 and the ram was set to sys linked i think.
i was considering on getting a new psu as i dnt know if this 1 inside is stable with the voltages ect.
hope some of you guys can direct me in the right direction, i was really just wanting 3gig anything else will be a bonus. pc is used for gaming cheers guys
