Help to overclock Q6600+water
12 Jun 2007
Ireland
ok now running on 293 x 9 , ram frequency 586mhz (1:1) , ram timings 5-5-5-9, everything on stock volts what should i do next? should i like change ram timings or its fine? increase volts on cpu or ram ?
Thank you for helping ;)
You should try keeping your ram at stock for now and just overclock the CPU to find how high that will go i have mine on 3.45GHz. Then once you have your cpus highest speed overlock the memory, this way if it becomes unstable during any part you know which it is that is unstable.
well i know most of that i just want to make sure i don't mess anything up when exactly do i increase cpu voltage and by how much ?
running now on 320 x 9 tried to go up 333 but at 330 windows did not boot and window popped up said overcloking failed i was guessing that cpu need more voltage.
few more thing i noticed in tat that first core is much hotter then other
and cpu-z, with ai suite jumps around. heres the picture
edit: im using b3
turn off EIST, keep the ram at 400mhz for now, drop the multiplier to 8 and set the FSB to 400, give it 1.3volts and you should be laughing :)
Edit, zomg noticed warez-bb in your ff! nice one mate im a member too:D
