It's been a while since I've paid any attention to my rig but since getting a G-Sync monitor I've been noticing stutters in some of the games I play which are really starting to annoy but cannot seem to track down.
Hardware wise my setup is as follows.
Motherboard: ASRock Z68 Extreme4 Gen3
CPU: Intel i5 2500k (using the 4ghz OC profile in the BIOS)
RAM: Corsair Vengeance 8GB 1600mhz (2 x 4GB) (CMZ8GX3M2A1600C9 - using 1600mhz XMP profile in BIOS)
GPU: MSI GeForce GTX 970 Gaming Edition 4096MB (No OC)
HDD: 2 x Samsung 840 Pro 128GB (1 OS, 1 for Games) connected to SATA3
SSD's benchmark fine and are hitting the expected speeds (>500mb/s Read, 300mb/s Write).
I've recently switched from gaming at 1080 to 1440 due to a monitor upgrade, however these issues were present before that.
Diablo 3 seems to do it a lot. When I first create a game it stutters for the first 5-10 secconds after loading then evens out. But the stutter returns at times when switching zones.
World of Warcraft (Blizzard again...maybe there's a pattern...) also pauses/stutters when switching between zones or phases (in and out of the garrison for example).
It's possible that these are normal with these two games and that everyone suffers from them however from watching other players on Twitch I can't say I've ever seen theirs stutter as much as mine.
Framerates are good 99% of the time, but I seem to be hitting spikes when the games appear to be loading assets in the background. Both D3 and WoW are well above 60fps most of the time.
I captured a video of the stuttering, but I can't say it shows it off that well.
I don't really have time to play much else so I can't say if the issue is there in other games. I can't seem to replicate the issue in the Tomb Raider benchmark.
Is there anything obvious I'm missing? I was considering purchasing more RAM. While PerfMon doesn't suggest that I'm hitting 100% RAM useage while gaming, it is getting close to 80% at times.
Are there any parts that could do with an upgrade for 1440 gaming?
Any advice is most appreciated.
