- 11 Sep 2008
- Co. Durham
Hi all
Forgive me starting a double post but i think it got lost in thread
The Vipers say 1.65v but the UD5 does not have the option is it safe to go 1.66?
cpu ratio - 20x
bclk - 200
DRAM - DDR3-1600MHz 1.64
Turbo Mode - Disabled
CPU Voltage - 1.3v in bios
QPI/DRAM Voltage - 1.31v
Mem multi - 6 (just underclock it until 4ghz stable)
QPI Link - x36
IOH - 1.12
Load Line Calibration - Enabled i read that this a bad idea and can kill the board long term? worth keeping it off?
booted into windows started prime 95 BSOD withn 30sec temps where about 68c any help pls i not a pro at this as you can see
cpu ratio - 20x
bclk - 200
QPI Link - x36
IOH - 1.12
i have 1 green and 1 amber lol Normal or....?
