Hello OCuk
Long story short, I am with BT or my parents are..and of late its been dail up slow and I can not do a thing about it.
I have tested it in the test socket in the master socket, no change, done silent tests and it seems normal( the normal quiet electronic hiss) I am at a loss, it can't be the houses wiring (again) as the test socket does the same, I have replaced the ADSL filter, no change...so what can it be?
here is the stats for currently on the BT home hub 2.0 ( when BT stop mucking about with it)
The Noise margin did go right down after I phoned up bt but they went back up over night
I dunno what else to do short of getting another router/hub to use than it might not sort out this issue
**Edit**
Before anyone asks
Cheers for your time.
Line state Connected
Connection time 0 days, 0:26:48
Downstream 283 Kbps
Upstream 446 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 34.6 dB / 20.1 dB
Line attenuation (Down/Up) 18.5 dB / 9.4 dB
Output power (Down/Up) 20.9 dBm / 12.2 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 0 / N/A
HEC Errors (Down/Up) N/A / 0
Error Seconds (Local) 0
Downstream 283 Kbps
Upstream 446 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
**Edit**
Before anyone asks
