Help tweaking my Rampage 2 Extreme setup
18 Jul 2009
I was wondering if someone could take a look at my settings and help me squeeze out the final mhz possible and possibly let me have HT. I can't raise the vcore anymore as CPU-Z underload says the vcore is 1.376.
The settings I used is pretty much some stuff I copied while googling.
The setting are stable at 20 runs of Intel Burn Test maxing at 71 degress at one of the cores on water.
Specs:
i7 920 D0
Asus Rampage 2 Extreme
OCZ gold 1333mhz 6GB
CoolerMaster RealPower Pro 1000W
Settings:
Ai Overclock Tuner [Manual]
OC From CPU Level Up [Auto]
OC From Memory Level Up [Auto]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
***CPU Configuration***
CPU Ration Setting [21.0]
C1E Support [Disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetch [Enabled]
Intel (R) Virtualisation Tech [Disabled]
CPU TM Function [Disabled]
Execute Disable Bit [Disabled]
Intel (R) HT Technology [Disabled]
*Active Processor Cores [All]
A20M [Disabled]
*Intel (R) SpeedStep(TM) Tech [Disabled]
Intel (R) C-STATE Tech [DIsabled]
BLCK Frequency [200]
PCIE Frequency [100]
DRAM Frequency [DDR3 - 1203 MHz]
UCLK Frequency [2406 MHz]
QPI Link Data Rate [Auto]
Load-Line Calibration [Enabled]
CPU Differential Amplitude [800mV]
Extreme OV [Disabled]
CPU Voltage Control [Absolute (VID) ]
CPU Voltage [1.32500]
CPU PLL Voltage [1.81592]
QPI DRAM Core Voltage [1.20000]
IOH voltage [1.11341]
IOH PCIE Voltage [Auto]
ICH Voltage [1.11341]
ICH PCIE Voltage [Auto]
DRAM Bus Voltage[1.65681]
Debug Mode [String]
Keyboard TweakIt Control [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Dealy 300ps]
IOH Clock Skew [Auto]
Let temps be your guide mate. Don't get to fussed by your voltage under 100% load, the only time you will ever be loading your CPU 100% is when you do that test.
Want to know what I think is the best stabilit test you can get? Play your favorite game for an hour or more. If your system handles that then it is just fine.
I don't hold too much stock in all those stable systems that can do 20 passes of that test or 20 passes of this test. Then they fail in the first 5 mins of a game.
The stability tests have value, don't get me wrong, but your system needs to be stable for what you want it to do. If it does that then all is good. Yeah?
Now what is the max BLK that you have been able to achieve.
Have read here.
LINK
I'm using a BCLK of 200 with a multiplier of 20 only on stock voltages! All under water too using the same processor and motherboard and my temperature is the same as stock settings too. All stress tested and stable.
