- 3 Mar 2004
- West London
Hi,
I've had an X2 4400 (socket 939) paired with an DFI NF4 ultra & GSkill ram for over a year now (overclocked).
Today I went into bios and set the 'optimised defaults' for both the RAM and CPU (default timings, voltages).
Now the PC doesn't post at all
It would show the graphics card logo, and then show the DFI splash screen with the BEEP but it'd just freeze and I couldn't even enter the bios..
So I opened up the PC and have tried all number of things, from using just one stick of ram, to setting the jumper to reset CMOS, and also removing the CMOS battery.
It seems as if the computer can't handle default settings any more
At one point when i was fiddling around with one stick of ram and the cmos battery completely removed, it did get past the DFI splash screen and alerted me to the fact there was no keyboard present (of course.. i took everything out, unlucky since i think i might've been able to enter the bios)
Also - it;s stuck on 2 red LEDs, with 1 stick of ram in the first orange slot going in from the board. However it gives 3 red LEDs if i put the 2nd stick of ram into the other orange slot, so i'm worried i might've killed some ram at the same time
Can anyone help? Is there an issue with some hardware that's suddenly occured? Or is there another reason it's being tempremental?
Posting this from the ancient laptop... thanks!
It would show the graphics card logo, and then show the DFI splash screen with the BEEP but it'd just freeze and I couldn't even enter the bios..So I opened up the PC and have tried all number of things, from using just one stick of ram, to setting the jumper to reset CMOS, and also removing the CMOS battery.
