I need some help understanding this please because I want to overclock my titan x.
I Was wondering why every GPU I buy it shows higher clock speeds in both the above benchmarks. I had a GTX 780 (not overclocked) GPU boost would keep clocks running at constant 1032mhz as opposed to the factory boost clock of 941mhz, which is of course normal,however in the above benchmarks it would run at 1228.
After buying the 980 similar thing & now I bought the titan x
I'm wondering is this benchmark showing the potential,or safe overclocking speed that I could boost to...?Is this the benchmark stressing the GPU to show this purpose?
Obviously gpuZ & after burner show normal speed. I have not overclocked before & have bought my first GPU 4 months ago & have now got my 2nd/3rd & want to learn about overclocking. Thanks in advance for you input guys.
