hi all, recently built a new PC (spec in sig) and today, twice, the rig has frozen. while watching a vid, the sound repeated over and over and nothing responded. had to hard reboot to recover
now afaik, if its memory, you usually get reboots while if its the cpu - you get lock ups. on top of this, the intel hardware monitoring prog flashes red with the CPU core being ' out of range' frmo 1.8 to 1.2v
to try and work around this i checked out the bios to try and increase the voltage to the cpu a notch but cant find the option! i found ram options, MCH options and host burn in modes and &s but no vcore
i found this on anandtechs site re: overclocking this mobo but i cant find the options
