Hello all!
I'm hoping some of you guys will be able to help me pinpoint my problems, and find a solution to them.
My PC seems to be very unstable whilst playing high demand games. It'll be fine for around ten minutes, and then it'll freeze up.
I assumed heat was the issue, but upon measuring GPU core temps etc, these never reach more than about 80C, with the GPU fans never reaching over about 50% usage, so I've ruled that out.
It's an Antec case (the entire system is from Overclockers, no changes to their spec except for adding an additional case fan), it has 6 120 mm case fans, and 1 200mm case fan.
I have a pair of GTX280 cards running in SLI configuration.
1000W PSU
i7 965 running at 3474.5 Mhz
12 gig of DDR3 RAM
ASUS P6T Deluxe motherboard.
I have a dual boot system, and the problem occurs on both XP and Vista, though seemingly more so on Vista.
I'm at a loss, I really don't know where to look. Any ideas would be much appreciated. Any more info you may need, don't hesitate to ask.
Thanks all
1000W PSU
12 gig of DDR3 RAM
Thanks all
