Help - Upgrade Questions
Permabanned
29 Sep 2006
Currently run :
ASUS A8N Premium mobo
San Diego 3700 (s939)
2gb Corsair XMS DDR
7800GTX
To get a Dual Core (maybe Conroe) do I have to replace the lot? and if so can someone point me in an economical direction?
cheers
yes for conrow you will need a new mobo new ram conroe cpu and not sure about the gfx. is it pcie ?? if so can use that in your conroe system :) if its agp then really you should get a pcie card.
what sort of money you want to spend ??
you can get a nice sum for them parts when you sell em. to help towards new conroe system
