Help upgrade to Win 10 problems
9 Sep 2015
Hi,
I tried to upgrade my Aspire laptop to windows 10 from windows 7 no when I switch it on I get a blue screen. Showing saying the boot configuration file has been missing some information.
I cannot press the F keys to get into the reformat windows mode and cannot do anything, any ideas please?
The lap top came with windows 7 and a partition to allow me to reformat and reinstall rather than an actual Windows DVD.
So I thought I wonder as I I have a Windows 7 DVD from another PC ill to install that version but it asks me what partition do I reformat to install it on it says the laptop has three partitions.
PQ SERVICE -15 GB
DISK 0 - PARTITION RESERVED 100MB
DISK 0 - PARTITION 3: MIKE 450.7 GB
Should I select the larger file MIKE, or will I cause damage as there is now three partitions probably one is Win 7 that came with lap top other I can only assume is win 10.
All help appreciated, if poss id rather not use another win 7 DVD and just get it to work past the boot error.
thanks for help
Just had a quick google.
PQ Service is your recovery partition.
Are you pressing ALT + F10?
You could try CTL ALT F8 and choose the RESTORE to factory defaults.
Apparently when you upgraded to W10, you may have overwriten the Acer MBR.
I got the info from here.
Hope this helps.
Thank you I was holding f4 the f8 trying all the f buttons to open restore but nothing worked. I'll try your suggestions when get back home. If I still cannot get it to work woukd installing Windows 7 on the large partition work? Or should I not risk it and try other options? Thanks for your help and tips.
