Help: Upgrading Memory
Permabanned
30 Nov 2008
Manchester
Hi,
I am upgrading my memory in my dell dimension 4400 and i don't really know what type to get.
It can take a max of 1gb which is what i am aiming for, the processor is a pentium 4, 1.80GHz if that matters.
Thanks.
I'm confused though because on that link its under DDR Ram and i thought it was DDR SDRAM and i need PC3200?
yeah very true, but SDRAM IS VERY OLD.! i doubt you have that,
simplest way to check is open up your case and take a stick of ram out, if it has 2 notches at the pins its SDRAM if it only has 1 then its DDR
but there is a pic of the slots on that site which show only 1 notch so im sure the ram i suggested is perfectly suitable..
From the dell website:
Memory
Architecture
DDR SDRAM
Memory connectors
two
Memory capacities
128-, 256-, and 512-MB non-ECC DDR SDRAM
Minimum memory
128 MB
Maximum memory
1 GB
Memory type
DDR (non-ECC)
BIOS address
F8000h
Picture of ram that was in;
http://i44.tinypic.com/2d0m0ib.jpg
Copy into browser.
I want to look around a bit tho and my mate might have some. If i am looking i ask for DDR or DDR SDRAM and what PC thing.
:o new find dell website;
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
PC3200 will probably be a heck of a lot easier to find, so get some of that and the computer will automatically run it at PC2100 speeds.
