Help Upgrading system for first timer
7 Mar 2011
Hi guys, this is my first post so please be gentle lol :D
I am looking to upgrade my graphics card, my PSU and also my monitor. Ive finally got around to put £300 on a side for upgrading my current system and would like your help in upgrading.
I would like a 1gb graphics card (not sure which one though :confused:), a PSU (not sure which wattage :confused:) and a 23" monitor (maybe LG or Samsung :confused:)
Wondering if anyone could help and point me in the direct direction?
this is my current system:
Motherboard Model: DQ45CB
Intel Core 2 Quad 2.66
4GB RAM
Available Memory Slots: 2
Total Memory Slots: 4
500GB HDD x 2
Soundcard: SoundMAX HD
Currently have a standard graphics card
system not been overclocked in anyway.
Hi, welcome to forums, I'd recomend the below
Gigabyte GeForce GTX 460 OC 768MB GDDR5 PCI-Express Graphics Card £124.99
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black £114.98
BeQuiet Pure Power L7 530W Power Supply £42.98
Sub Total : £235.80
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 20.00% VAT : £49.41
Total : £296.46
This keeps within your budget, if you can afford a little more, then change the gfx card to the following
XFX ATI Radeon HD 6850 Black Edition 1024MB GDDR5 PCI-Express Graphics Card £149.99
Sub Total : £235.80
DPD Next Day Parcel
Total : £296.46
thanks for the reply, sorry to be a noob but would the graphics card and psu fit in my current system?
What case have you got? Do you know? As long as its a standard ATX case the PSU definitely will and you just need to measure the length of space available for the gfx card
If you dont have a standard ATX case (if its a prebuilt OEM - eg Dell, HP etc you may not) you can pick up a case for around 35 which would do, alternatively you can pick up the Coolermaster Elite 430 windowed case with 500W PSU included for about £65 iirc
In the first picture, the long black slot on the right hand side, with the white retaining clip at the end, thats your PCI-E slot which is what the gfx card plugs into, measure the distance from the backplate (edge of case) along the black slot to as far back as it goes before it hits anything, likely to be your hard disk caddy, measure this in inches and as long as this is more than the length of the gfx card, youll be good to go
thanks, i have just measured it and there is well over 10 inches of space...i would just need to move some wires about but it should be fine... :)
would this be a decent enough graphics card to run majority of latest games?
http://www.overclockers.co.uk/showproduct.php?prodid=GX-186-XF&groupid=701&catid=56&subcat=708
its not going to run the latest games on maximum, but theres nothing wrong with it.
however, the number of MB is not really that big a deal with graphics cards. its the model you are interested in (eg, GTX460, or HD 5850, etc)
here is a comparison of how the card that is one level up from the one you found, and the other one that was suggested, compare: http://www.anandtech.com/bench/Product/296?vs=315
also, i have the GTX460 768MB myself (but i went for the asus one, not the gigabyte one which seems to have disappeared). but its still virtually the same card, so i could measure it if you need me to
I should be getting the monitor later 2day, still deciding on the graphics card and psu...hopefully this decision will be made come the weekend....
Can anyone tell me how difficult it is to change the psu? I hear gfx card is simple, plug and play, but the psu looks complicated! :confused:
Its not too difficult, just a bit more time consuing, you just have to remove all the wires connected to it first, there may also be a few screws holding it in position, normally 4 on the outside of the case just at the back
As I say just be patient and take your time, trace all the wires from the back and make sure theyre all unplugged, and dont force it/anything, if it doesnt want to move, have another look, you may of missed a connection or it might be snagged
Good luck
I'd go for this personally
Product Name Qty Price Line Total
**B Grade** MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card with FRE (GX-099-MS) £119.99
(£99.99) £119.99
(£99.99)
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black £110.39
(£91.99) £110.39
(£91.99)
XFX Pro 650W Core Edition Power Supply £68.99
(£57.49) £68.99
(£57.49)
Sub Total : £249.47
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £52.24
Total : £313.46
well i bought the LG W2361P, and been testing it...looks like a faulty screen...i have bleeding at the top and bottom of the screen when viewed on a black screen! :(
guys, sorry for the stupid question but if i buy a better graphics card would it improve the quailty of my display? e.g. as i write this message i am finding it hard to read because of the grey on black textbox
If it is noticeable bleeding, return it. You cannot resolve this using the colour, contrast settings.
