HELP !!! (Urgent) 290x not being detected!
I think if I want to have waterblocks on a card I will do it myself after I have tested to see it will run on air first.
Very nice work inside the case, real shame it didn't work out.
Did you try deleting the device inside device manager, then rescanning for new devices?
I've got a 270x that was doing the same thing in my Gene V board, appears in device manager but only when using the onboard, use just the card itself and no dice, tried another machine, worked, another card in my machine, worked fine, 270x back in worked fine, until today that is, now back to the same point, bios updated, gpu boos updated, its all a pile of crud...
Got another slot i can try in but need to strip machine out of case to get enough access...
I know this is a dead thread but it sounds similar to my problems
except i had everything installed gpu drivers everything it was working great benchmarking games what ever (all in a custom loop btw xspc razor block 290x)
installed advanced warfare and alt tabbed when i came back in my fps dropped to 15fps and was un playable now.
So uninstalled the drivers using DDU
reinstalled catalyst software and drivers and it came up with an error ever since then the pc booting got worse and worse so last night reinstalled windows
done all the updates and trying to d/l the mobo drivers are slowing everything down as it's only going 5kb/s
not sure whats happening but i have to have my dvid cable plugged into the mobo as the when its plugged into the gpu i get nothing on my monitor 2560x1440p btw
just downloading the updates manually of a spare pc then going to try and get them done on the other pc.
if any one else has any solutions let me know btw this is a new build 3-4 days old so no spyware mal ware virus as i had all the essentials on it.
sorry for the rant mega ****ed and not sure what to do hard to swap parts in and out due to being acrylic hard pipe
