Hi,
I've been trying to figure out why my internet connection on one of my pcs has suddenly dropped and can't fathom it out so I thought I'd post here and ask for help.
I am on virgin 50mb connection, but my main pc the connection is dire, when using speedtest (on the times it actually gets past the 100% screen or configuration load error) I get speeds of around 0.3 Mb/s, on other machines in my network I get a nice 50 Mb/s, so leads me to believe this is a machine specific thing.
I have had intermittent latency before (lag spikes but speed test would usually get between 5mb and 30mb then - I think started around the time I bought a new graphics card of all things) but noway near as bad as it is now. I think the big problems started at the time the firmware upgrade was pushed to my router (could be coincidence).
I had tried and tested lots of things including:
- Rebooting and Power cycling the router and PC
- Turning off Avast shields and Windows Firewall
- Stopping just about every windows service I can and using msconfig to not load anything at startup and to only start microsfot services
- Run in safe mode (same problem)
- Used onboard NIC and also tried 2 other NICs (one realteak and one intel)
- Network speed between pc's is fine - copying files at 80-90mb/s
- Ran MBAM (came up clean) and Avast scan (fast scan found nothing but full scan found a virus in one file - this is a file that's sitting on my old hard drive which I haven't accessed since re-installing windows 7 on a new hard drive so don't think thats the issue).
- Swapped cat 5 cables between 2 pcs, one pc works fine with either cable, main pc has problems with both cables.
Has anyone got any more suggestions, I am at a loss here
