help vista glazz done something
30 Dec 2007
Oxonfordshire
hi all, ok so i installed vista glazz after reading few on here and people asking to change look etc so i thought i try it but its done something and now i cant get pc to work.
error message says along the lines of : c:\windows\system32\uxtheme.dll is either not designed to run on windows etc try installing the program again using the original installation media.
is there anything i can do or is this a case of reformat and reinstall from fresh??
to late !!!
did try that but would say the same, but after a bit of searching i found i had installed the version which was not supported with sp1
so ive reinstalled and going thro set up now
guess i will try again but with the supported version and i will try with without installing anything else but sp1 see if it does again !!
