- 14 Jun 2004
- Tilchestune
I have a problem with the pc at the moment It will run xp64 bit no problems
but when i install Vista 64 bit ultimate it BSOD just after startup , the the pc will not restart claiming cpu or mem speed wrong ( nothing OC all stock ) after a Clear cmos it will post but not run vista, I have tried without raid 0 installed ,while it is a little better it will BSOD.
spec core 2dou quad core water cooled
evga 6801 mb
4 gig giel ram pc 6400 , Ihave tried with only 2 gig in same results)
2 x 500 gig sammy hd sata
bfg 8800 gtx water cooled
maybe the cause lian li case mb is it upside down
evga 6801 mb
