- 16 Mar 2006
- Telford
Hi Guys,
Just built a new gaming PC (old one was over 5 years old
) and I'm a bit confused with all the memory timing options. Last time I messed with timings you could only change the CAS setting and that was it
I'm using this memory:
OCZ 2 x 1GB PC3200 Platinum Series EL-DDR CAS2
CL 2-3-2-5 (CAS-TRCD-TRP-TRAS)
With an ASUS A8R32-MVP
Now obviously there's 4 timings specced on the box but the BIOS has loads more, what's the best thing to do with these - leave them as they are or try and lower them until I lose stability?
Anyone using the same setup and able to supply some recommended timings?
Thanks in advance
Matt
Thanks in advance
Matt
