I''m going to build my first PC
and wanted to ask you guys for some help, advice or just general comments. All are much appreciated!
These are the spec's so far...
GPU - Gigabyte GV-R695OC-1GD
MOBO - Asus P8P67 LE Rev3
CPU - Intel i5 2500K 1155 OEM
RAM - Corsair Veng White 8GB DDR3 1600 1.35v
HS/F - CoolerMaster Hyper 212 Plus
CASE - CoolerMaster CM Storm Enforcer
PSU - CoolerMaster GX 650W PSU
*I'm not going to purchase a HDD until the prices drop... or I may consider SSD.
How does it look? Is there anything you would change?
Also I was wondering if you guys could help me decide on a motherboard... mainly what to go for?... i had these in mind:
Asus P8P67 LE Rev3 or Asus P8P67 Pro Rev 3.1
The ''Asus P8P67 LE Rev3'' seems very good value for money. I'm just not sure if it's worth spending the extra £40 on the ''Asus P8P67 Pro Rev 3.1'' when I could put the £40 towards more RAM or ''something'' else.
Cheers for taking the time to read this.
Ash
and wanted to ask you guys for some help, advice or just general comments. All are much appreciated!These are the spec's so far...
Ash
I don't really get the P8Z68-V LX comment, it allows you to use the onboard GPU, as in, along side the 6950? will that give you much of a boost in performance?
