help wanted pc wont boot
1 Jan 2007
hi all, recently i posted about a silent pc solution, and took some advice to get a new case with noise dampening, and maybe add a passive gpu at some stage, so i bought a new case, transfered all my parts into the new case, and it would not post, just cycled through off and on every few seconds, so i tried different parts and came up with the notion its possible my m/b, anyway no one sells any lga 2011 motherboards now other than from the far east, so i bought one , when it arrived 2 weeks later i decided to do a box test and everything seemed to work but i had no gpu in, but it wasnt cycling on and off, so i put it all into the case with a gpu and no video output, and no keyboard and mouse lights, i have tried a different gpu, psu, i have tried one stick of memory, and using different sticks in different slots, now the only thing i cannot test is the cpu, as i dont have a spare one, so is there anything else i can do or is it most likely the cpu, any help would be appreciated.
system is
intel 3930 cpu
samsung green ddr3 x 4 sticks
cheap m/b with no manual and cant find a manual
corsair 240mm aio cpu cooler
dvd-r drive
250 gb samsung ssd
motherboard is this one if anyone can help with a manual at all - https://www.ebay.co.uk/itm/NEW-Inte...c:g:dFYAAOSwVBRb-Pwz:rk:2:pf:1&frcectupt=true
That CPU is LGA 1551 is it not... A Celeron..
That board is X79 on LGA 2011...
Have I read this right....
no the cpu is x79 lga 2011 6 core.
also i have just bought a new full upgrade and a new psu, will try the new psu before i fit the new upgrade, decided to get i9 9900,
bloody typical, so i bought a new system and a new psu, anyway the psu came today before the rest of the system, so i decided to try in the pc that im having trouble with and hey presto works first time, but i tried the psu from my main pc and it didnt work but its still working in my main pc, weird i know. hey ho.
