- 28 May 2018
Hi, I'm new to this forum and also new to custom water cooling, I currently run a FX 9590, and Fury X each on their own closed loop systems, I'm going to be building a new TR system in the coming months, with the current issues I have with the FX chip I have I was thinking a overkill closed loop would be great, my Corsair H-100i only just copes and I had to turn turbo off.
I know TR will not run this hot but I just would like an all in one solution for all components.
The new system would have a 480mm rad, that's all I know about the water cooling side..
I need to know what fittings I need, what pump, what resoiviour, piping, liquid, ect..
I would like to keep it as distilled water, also I need to find a block and plate for my Fury-X.
I'm not sure what else to add.
My case is a thermaltake core x9, PSU is getting on a bit but it's a coolmaster 1kw PSU [semi-modular].
[Edit]
I also need ram modules, gpu, CPU, mother board, all to be cooled.
[Edit]
