Hello,
I have a pc consisting of the following components:
Gigabyte GA-965P-DS3
WinXP Pro sp3
Intel Quad Core running at stock speed.
4gb Ram
Corsair HX 620 psu
ATI 8800 GT
Sorry, it's been a while since I've been into the thing and so I'm a little sketchy as to whats in the thing. Howeer, I'm more or less correct.
So I was playing a game the other night and everything is fine, then suddenly the game takes from its usual 20 secconds save time, its taking so much longer by 10 minutes I was worried. At 30 minutes I had had enough and hit the 'reset' switch.
The computer went through its usual boot routine but was noticeably slower, it found each drive and in turn it needed to 'scan' each one to ensure that the 'file structure was complete', so I let it go through that scanning as it went. Then we're into the desktop environment and things are noticeably sluggish, it takes a good 10 minutes to populate the desktop of its icons. That completes and the system runs slowly, but turnng off the system meant waiting another 10 minutes.
Resetting the system, didn't do anything, neither did using the old System Restore, it booted slowly back to this environment.
So looking through the eventviewer tells me that I've an 'atapi' problem, it points to not the dvd drive but insead the Harddrive, disk 0 in fact. So I purchase a replacement harddrive, it arrives then a friend and I set about rebuilding the system with this new harddrive, it's noticeable quicker using this new drive however, as soon as we put the drive back into the case. Everything gets sluggish back to things as it was, the problem doesn't seem to be the harddrive.
Reconnecting the old drive, as long as it's outside the case supports this, as does leaving the new drive outside the case. We check all the cables to the Corsair everything is fine, bar one that's a little exposed which we put electrical tape around, putting the drives back into the case = sluggish response.
Taking drives out system works flawlessly Arghhh ffxxxxxx!! Ripping all wires\cables out and reconnecting and everything is as it should be, everything is fine and double checked, everything is as it should be. However, the dame thing doesn't work as it should!
Has anyone any ideas as to what the problem could possibly be? Please!!
Thank you for your time.
WinXP Pro sp3
4gb Ram
Corsair HX 620 psu
ATI 8800 GT
