HELP! What else do I need...
17 Aug 2012
Tamworth, UK
Hi,
So I want to try and get my rig under water this weekend coming up and have the following parts ready to be soaked:
I am missing the following:
YOUR BASKET
1 x Hardware Labs Black ICE Radiator GTX-Lite 360 £50.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack (CO-9050005-WW) £13.99
2 x Mayhems X1 Blood Red Coolant £7.99 (£15.98)
2 x Primochill Primoflex Advanced Tubing 16/11 - Clear £5.99 (£11.98)
1 x XSPC G1/4" 4 Way Fitting (Black Chrome) £3.95
2 x XSPC G1/4" Plug (Chrome) £1.55 (£3.10)
5 x XSPC Radiator Screw Set 6-32UNC (Black) £0.49 (£2.45)
Total : £112.94 (includes shipping : £8.75).
What am I missing or overlooked?
The long screws will be okay for the rad in the roof & fans to mount to it?
The Spoiler spec is a rough idea of my spec not all of it is the same.
I have a 3820 CPU, RS240 from the MM which had no screws so I'm making sure I have everything ready.
I already have a block for my CPU which is installed on the board so that's covered.
