MODEL ssr 750fx seasonic focus plus 750 gold 80 plus gold , today when i shutdown my pc and turned it off from the wall i noticed a spark come from the wall switch , I then tried to turn my pc back on to see if it was working but it didn't turn on, so i tested the cable and that was ok , I tested the power supply and it was not working so i decided to open up the power supply, there was no burn marks and the caps from sight look ok, i did test the fuse from the power supply and its bad . It doesn't look easy to remove the fuse it looks like its soldered in with to cap ends , I am not sure if this is the only problem but it could be an easy fix if its just a bad fuse only . i am not sure what type off fuse i need to get to replace this one ,
