Help What Router For Blueyonder?
18 Oct 2002
Livingston
A family friend has blueyonder and is wanting to go wireless. She only has a laptop so I'm needing some advice on what's the best solution. I have ADSL and use a Netgear DG834G which works great.
I'm thinking of going down the Netgear route again with:
Netgear WGR614 54Mbps Wireless Cable DSL Router (NW-010-NG)
Netgear WG511 54Mbps Wireless PC Card 32-bit CardBus (NW-009-NG)
What are people's view on the router? Is good/bad? Should I look at another make?
Any advice is welcome :)
Anyone? I need to get the kit ordered, so I can install it over the weekend :)
Sorry for being impatient!
Linksys WRT54GS Wireless-G SpeedBooster Broadband Router/4-Port Switch (NW-006-LS)
Linksys WPC54GS Wireless-G Notebook Adapter with SpeedBooster (NW-011-LS)
I think those should do the trick. Or go for the models without the Speedbooster.
i'm with Blueyonder and the WRT54GS works perfectly.
Second vote here, exact same kit.
Seemed to be a little flaky at first so i use static IP, never went back 400k/b ps on some stuff :).
Cheers I'll consider the Linksys, does anyone have any experiences with the Netgear WGR614?
