Hi guys,
Have two options specc'd out, but please feel free to suggest others.
1 x MSI K8N Neo4-F SKT939 nForce4 chipset Dual DDR400 PCI-E ATX 98137 £42.70 £42.70
1 x AMD (Venice) Athlon 64 3500+ 939pin 512Kb L2 Cache 90nm Retail Boxed Processor With 3 Year Warranty and Fan Included. 88107 £59.94 £59.94
1 x Point Of View GeForce 7600GS 512mb DDR2 800MHz PCI-E 110066 £82.95 £82.95
1 x Western Digital WD400JB Caviar SE 40Gb 7200RPM ATA/100 8MB Cache - OEM 40469 £24.72 £24.72
1 x Arctic Cooling Silencer 64 Ultra Socket 754/939/940 CPU Cooler 74453 £4.49 £4.49
1 x ***** Extra Value Thermal Compound Silver Grease
This would use my existing (DDR1) ram and I have a bigger hard drive for storage. Total cost: £263.81
OR:
1 x Abit NI8-SLi GR SKT775 Nvidia C19 chipset PCI-Ex2 7.1channel audio ATX 105796 £48.15 £48.15
1 x Point Of View GeForce 7600GS 256mb 128bit DDR2 PCI-E 110064 £72.74 £72.74
1 x Intel (BX80551PE2666FN) Pentium D 805 Dual Core 64 bit LGA 775 2 x 2.66 GHz 2MB (1 Mb per Core) Cache 107617 £69.24 £69.24
1 x OCZ DDR2 Value Dual Channel Kit 2x512MB DDR533 PC4200 CL 4-4-4-12 (LIFETIME WARRANTY) (OCZ25331024VDC-K) 80183 £47.99 £47.99
Total cost: £291.00 and that includes new ram (hard disk would have to wait).
What are the views? I really can't decide for a midrange AMD 64 (single core) or the Pentium D.
It's for gaming and digital photography manipulation. I just like a speedy PC
Thanks!!!
James
OR:
Thanks!!!
James
Use the current 200GB (i.e. partition it properly) then add another 200+GB later on when you need
