So I got my PSU back today from RMA, wired it up, plugged it in, turned it on...Click...Click...Click!!!
My first thought was that the PSU had been sent out DOA (its a Seasonic 1000w Platinum to replace the XFX version in sig) - did the paper clip test and the fan span up briefly.
So I unplugged everything but the MOBO 24pin and fans span up etc etc... cutting a long story short, it STOPS working if the 8pin CPU power is connected.
Does that mean my CPU is dead? likely? or the MOBO? or any other ideas?
Everything should be in warranty but not sure what's bust (last time I sent back a CPU it WAS the MOBO.
I have been sans PC for about 6 weeks now!! I've had to play Xbox, eughhhwwwww
Safe mode didn't work either as it needed the raid drivers to boot. That was with winXP though, you may be lucky.
