- 1 Feb 2008
When using a multimeter, you really need to check it under load.The only way to test it is to do it properly with a multimeter. I dont believe its that low, Voltages have a bad habit of being mis-read. Mine is at 1.2V according to speedfan. However, if its locking up, it could be that low.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-085-AN&groupid=701&catid=123&subcat=
Is a good enough PSU if you really dont have the cash.
