I have a B 450 A Pro max mobo.
And an Artic Freezer Liquid 2 240 cooler.
There is one cable (4 pin I think) which I plugged into CPU_FAN 1 on the Mobo.
Fans come on. Ive not been into the bios yet, so I havent set anything up.
There is another cable. Im not sure where to plug it in.
I also note that the coolers RGB lights are not on yet.
The other cable is slightly different.
- It has space for 4 holes
- In a row, it looks like:
2 holes, no hole where there is plastic, and another hole
- One of the holes is covered with plastic
- The plastic end-bit, is slightly thicker than the other cable.
Anyway, I dont know where to plug this second cable. There are no connectors on the mobo which have 4 pins and one of those 4 pins missing.
New to this. What am I missing?
Thanks for your help guys, appreciate it!
