HELP! which monitors are right for me
6 Jun 2005
Plymouth / Cambridge
Hi All,
I have been looking at monitors for quite sometime now but have been very reluctant to part with my cash and buy 2 x 23/24” versions. Quite simply at the monitors think I want will cause me to invest in a new graphic card or more likely 2 which is added expense.
I have been looking at two of these for a while Samsung S23A750D 23" the trouble with them is that they only support Display port which my ageing GTX 295 does not have.
so in order for me to get these monitors I’d have to purchase 2 Nvidia cards to get 120Hz on each.
My options thus far have been to get an ATI card. But i don’t want to do that as i have had trouble with ATI in the past and think that there driver support is something to be desired.
So...
What else can I get if I don’t these. I currently have a NEC 24wmgx3 which is a fab monitor i just want 2x 120Hz, 2ms and good Gamut’s for art work, 3D and the odd game. I’m not to fussed with 3D.
I know this is a rather hard question to answer. And will most likely have to compromise on say the Colour reproduction of the NEC although there are some very good TN’s about these days if you spend a bit more. Currently running with 2x 22” Sync master 223bw at work which I love using.
Anyway I would really be grateful for any help or recommendation on other brands, news, things on the way in the near future. PCM any thoughts?
summery / wants:
23/24” display
120Hz
Good colour
Viewing Angle 170˚/160˚ (same as the 223bw)
Thx
Paul
