Help! Which TV Tuner
Don
9 Jun 2004
Which TV tuner will i need so that i can connect:
1. My Sky box
2. My xbox 360
3. My PC
all to my lcd monitor?
Thanks
I wouldn't use a tuner to connect any of those devices to my tv.
Sky I would use RGB scart.
PC I would use VGA and Xbox DVI.
If your set doesnt have DVI and VGA then stick the Xbox on component.
Sorry i didnt explain it well; i have a Viewsonic VX912 19" monitor for my PC and i want something so that i can connect my tv, sky box and 360 to it.
Does your graphics card have any kind of inputs and are you using both DVI & VGA inputs on the TFT.
Still need more info in order to even offer basic advice.
