- 5 Mar 2011
Hi all!
I have 3 VTX3D 6970s and they are getting a bit hot in such a confined space so I want to watercool them. Luckily I decided to check the board before I bought a reference block. There are some differences between this block and the reference, V1 and V2.
Here's the board, notice the second line of capacitors instead of 2 groups:
Does anyone have any experience watercooling this board or could anyone suggest a block that would fit?
Thanks
Thanks
