Help which way do the wires go round ??
9 Sep 2009
It's a HP ze2000 which took apart to replace the fan... help !
Just try it, you won't do any harm if you get it wrong you may get a weaker signal and can then just swap them over.
Like I say ones I've seen if memory serves me correctly had grey to main. It may have been connected wrong to start with for all I know though.
Also a quick scan of google images found :
image 1
image 2
