Help! wierd monitor buzzing noise when surfing webpages
5 Oct 2008
Hey, got the 3D acer monitor, when im surfing the web, i noticed a wierd buzzing noise, but as soon as i dont view the page and go on something else it goes away?! what the hell? anyone else got this problem
Open Notepad. Maximize it. If you get the buzzing it's probably a monitor issue.
If you don't, the buzzing is probably caused by Flash on webpages. In which case it's a video card or cpu induced buzz.
I have heard that particular issue many times with that monitor. Do you have dynamic contrast enabled? Is it always there when you're just on the webpage or when you scroll?
It is always on certain websites, with like certain colours/shades, the noise goes higher or lower, if i turn off 120hz this no longer happens
