- 17 Nov 2011
I just installed windows 7 pro on my pc i just built and i cant do anything...not even connect to the internet. it says i need to install drivers but how? i cant use the internet to download any ...
Erm...
Wow, ok, if you just built yourself a new rig, the hardware presumably came with driver disks?
why don't you have a driver disk with the new motherboard?
if you really don't have it, the answer is quite obvious. download drivers on a computer with internet access and then copy them to a usb stick (or burn to DVD) and then install them on the new PC.
Because i bought the mobo used and it didnt come with it -.-
