- 29 May 2007
- Sunderland/Worcestershire
Hi people, its been a while since I posted here but I'm pretty desperate!
I've just moved home from uni and when I set my pc up it wouldn't connect to the wireless network properly, it would connect then disconnect and never had a constant connection. I tried a few things, ending with physically removing the internal wireless card and re-inserting it,with a couple of re-boots in between.
This didn't work so I got the belkin n f5d8053 v6 usb wireless adapter from another pc and plugged that in, this is where the problems started.
As i had no internet access it didn't install drivers when I plugged it in, so i downloaded what looked like the driver package on my phone and moved it over via usb. When I installed it it also installed a programme which closed as soon as it opened. This was the start if a whole world of problems, the wireless never worked, it started hanging closing down and starting up, multiple installs of windows on different hard drives later and I'm no where....
To top it off, I just got cold called by someone saying my computer was infected with a virus and if I installed a (remote access) programme he would fix it for me. Computer (and laptop) are now unplugged from the router and their wireless turned off, so im doing this on my phone...
I'm not sure where to start, I ran avg on my laptop and it found nothing, pc is currently in safe mode and laptop is running a startup repair, although I'm not sure what this will achieve!
Anyone got any suggestions of where to start?
Cheers
Richy
Cheers
Richy
